Cheapest 3d Mapping Software
That is a big area. What resolution do you need?
Theoretically, you could do it with a Mavic and Drone deploy.
The limiting factor for Drone deploy is the total amount of data you upload.
Therefore, if you set it up to take photos from a very high altitude (eg, 500m) it could capture a lot more area in each photo and thus reduce the amount of passes it would need to do up and down the field, and also give you the best chance of not exceeding your data upload limit.
But, will the resolution be good enough for you at this altitude? And are you allowed to fly to 500m at this location?
I could not fly above 120 meters in canada, and the resolution expected is about 5 cm!
I will have to wait the new Mavic Pro :)
You would produce and extremely large amount of data at 120m, and would churn through, I don't know, 50-100 batteries?
For the hassle, I think you'd be far better off getting paying for proper aerial photography
Yes Yannie this is also my opinion , the area is too big to be covered by drone, maybe a fix wing like ebee aircraft but not with my Mavic pro.
Thanks for your quick reply
pilot74sparki
