Checking in from New Mexico
Checking in: New Mini2 pilot in NM and having a blast. Great beginner product. I am looking for a cable to attach the controller to my iPhone that has a straight-in plug instead of one with the 90 degree bend in it. The 90 degree will not plug into my iPhone unless I cut my IPhone case to allow it to seat. Appreciate any recommendatW
Checking in: New Mini2 pilot in NM and having a blast. Great beginner product. I am looking for a cable to attach the controller to my iPhone that has a straight-in plug instead of one with the 90 degree bend in it. The 90 degree will not plug into my iPhone unless I cut my IPhone case to allow it to seat. Appreciate any recommendations.
Welcome to the forum! I am also in NM and fly a Mavic 3 and Air 2s. I usually get all my cables from either Amazon or Ebay. I needed a cable with a straight end to connect my Galaxy S8 to my controller for the Air2s. I can send you a link for that one and maybe you can follow it to find one for an Iphone if that helps. Hope to fly with you some day, I have been trying to get some people together from NM to fly but haven't had much interest, lots of great places to fly around here!
Welcome from across the Rio Grande in Corrales. We'll attend the Sunday morning Mass Ascension with our son and his girlfriend. This is our 19th Balloon Fiesta, and it never gets old, especially when the balloons land around our house. Unfortunately, we live within the TFR, and I can't fly my drone.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New Mexico, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning…
Nice rundown of newbie tips.👍
Welcome to the forum! :)
Reactions: LoudThunder
boatdoc
