Checking in with my first drone....kinda
a5tra3a
Calgary, Alberta, Canada
Hello Everyone,
I just got my first well sorta (I had a Parrot AR 2.0 Drone back years ago but only had it for a day before returning it) done for Christmas and though I haven't flown outside yet I have done a few practice flights inside. I got a DJI Mini 2 with the Fly more combo and have finally gotten the rest of the accessories that I wanted to have before flying. I hope to be flying outside soon, once I get my checklists and logbooks sorted, and yes I know they are not required for the sub 250g drones I plan to work up to something like the Air 2 and then onto the Inspire 2 or something similar to those when the time comes and want to have solid practices from the beginning.
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching. Thumbswayup
If I might make one suggestion it would be to register your Mini 2 anyway. It's a generic registration and they don't even ask for the drone's serial number. It takes less than 10 minutes and $5. So if you throw on some leg extentions/landing gear (highly recommended ) and maybe a strobe or two you don't have to worry about being over the legal threshold even though those accessories are minimal in weight. Should you decide to add the Mavic Air 2 or other drone to your collection you would use the same registration number unless by that time you have a FAA Part 107 certificate, whereby both drones would need to be registered separately.
Welcome to the forum!
I would imagine that flying Banff’s not allowed, but can you fly just outside the Stampede? That Mini 2 can probably do it quietly.
Safe flying in 2021 to you!
We can't fly in Banff or any Federal or Provincial Park as well as a number of parks in the city that I live in but I am very close to the edge of the city and also away from the airport which is nice. I am not sure about the Stampede Grounds though, I have seen people fly from Fort Calgary which is very close to it so it is possible.
Being in Canada I could register but as far as I am aware I would then also need an RPAS basic or Advanced license which I do not yet have. Though I am working on getting them, I am going to spend some time working on my checklists and also my documentation process. So far I have a binder with a basic spec sheet on the drone as well as a list of all equipment I have with serial numbers and a copy of all the receipts for everything that I have as well. I have also started testing out some apps for weather, NOTAMS and flight trackers for manned aircraft to see what I want/need in my toolkit.
DanManNYC
