Crack under gimbal plate
Yes.. lot if work for a little item. There is enough of a stump remaining to make up a "sock" that can be made into that form. A little appropriate adhesive would secure it . I have a contact that has a 3D printer. Might give that a go.. otherwise I'll need to purchase that plate. Thanks for the heads up.
Your solution might be better instead of disassembling the whole mavic just to replace that part. Just try to make sure the part you use as a replacement is as close to the OEM one as possible because it does serve an important purpose in keeping the gimbal level and not letting it overextend itself.
Kia-6098.111
