Crystal Sky and Spark
I'm using the above it works fine I did experience a few seconds lag using wifi which seems bonkers as it has wifi and a dji product ! I am using the goggles cable with a USB rather than the one above looks much tidier I will get on the case and order one of those cables thanks for sharing
Reactions: Advexure
Yes, using the DJI 90 degree Type-C cable is nice and clean. Also good to use the bottom Type-C port inside of the side Micro USB as it's too easy to jar that side input connect with Micro USB. Micro USB is a rather weak connection and I know from experience by jarring a cable and the connector breaking off and falling inside the peripheral (happened to me on a GoPro HERO4).
So let me get this straight it’s a type C to CS and then micro to spark controller?
deepdark
