CrystalSky 5.5 with dji mount
You have to manually rotate the screen in the settings menu
img_0673-jpg.22023
I used two keyrings and then put them on the lanyard clip
Reactions: Ping^Spike
Is there a way to lock the screen in the flipped state, every time I put the screen on to the bracket I have to go into settings and flip it.
Reactions: ghedgepath
I believe that by default each time the CS is turned off it goes back to normal
Reactions: philh24
Hey guys here's a heads-up on the short cable attached to the DJI mount...if you remove the monitor from the mount you will notice a rubber pad...peel it up..it's just glued...and you will find 4 Phillips head screws...remove them and the locking mech. Comes apart and the cable can be removed easily.
No sir...it's very easy. The part that mounts to the controller has a rubber gasket on it, just peel it up and you'll find 4 small screws, just remove them and it will come apart
And it’s just a regular USB-C cable? No soldering etc.
Assume that cable cab be replaced with a longer usb-c to usb connection?
anton13
