Crystalsky and Mavic 2
Camera controls on controller or CS?
Both work fine with my 7.5 inch. Drone is one level back on firmware. CS is current on firmware. Not sure on DJIGO4.
Paul C
Reactions: OU6799V
Works for me
Working OK on latest DJIGO4 on my CS 7.5" and my CS 5.87" and the remote controller. Drone on the latest update.
Possible thought .. reinstall DJIGO4 application.
I didn't ask you if it worked fine on yours, I ask if anyone knew why the camera and video did not work on my Mavic Pro 2, but did work on my Mavic pro.
@jcw7268 My CS 7.85 works fine with my M2P. Camera controls on the stock controller and the CS work fine and as per the manual.
On the right side of the CS controller screen there is the image of 3 sliders... tap it to adjust all camera settings. On the CS you can place a finger, hold, and s blue circle appears around that point. Without lifting the finger slide it to move your gimbal, or you can still use the left side wheel on the controller.
deepdark
