They often don't update the site until days after the GO4 releases ...just checked dji website still dated 29/11/17 so still old 4.1.18
Your version says 470 Google playI installed via the apk and it definitely shows 4.1.22 when it is installed.
You have rain??? wow....Raining here so haven't tried it yet
Loading 4.1.18 created numerous problems on my android tablet and phone...disconnects with Sparky, lags and a different set of weird setting changes when connecting either Mavy or Sparky, plus the inability to use the radar map and flight map at the same time. I spent a few hours over three days fiddling with a fix, like reloading and changing connect sequence, etc., even called Josh at the DJI Colorado store (who BTW is well skilled at explaining fixes) and he was stumped. Then I went to the APKmirror site and reloaded 4.1.15. Presto, problem solved. I have an old Samsung G4 that will now be my test equipment for new versions of the app.
Have just finished testing Go4 V.22 and so far all looks good. No problems have manifested them self.
What I have found is the video link and pixilation seems to have been fixed as it now runs smoothly on Samsung S5 where V.18 was still a bit pixiated at times.
2. DJI have now switched back to Google maps and are again trailing the maps as a onlune service. There is no way in settings or menu to cache the maps but there is a switch in settings that allows to switch between Here maps if you have them cached and the new streamed google maps.
Everything seems to run smoother and all settings remained the same after update.
Where in settings does it allow to go between Here maps and the google maps? I don't see it...
I saw an option when first starting it, but that's it.
