DJI RC (mini 3 with display) controller disassembly
There's more DJI RC teardowns over at
Again, nothing we have not seen before. Just like the RC Pro, there is limited traces to its P1 processor, making it difficult to figure out debug/serial lines.
Reactions: GadgetGuy
Have you located the exact position inside the RC-Pro, to know where to drill a hole through the case to get to it, without tearing the case open? It's different than the Smart Controller, and it's well documented on the RC-N1. Just no clear tear down on the RC-Pro yet. This is the best I can figure out from the FCC filings.
Okay, so I have it opened, but its really hard to measure. My measuring tool doesnt reach all the way down to plastic, so the result might be a bit off. I tried my best, and it seems the speaker is 5.86 cm off the side (C2 button side), and 4.45 cm off the top. Always measured from the outer edge of plastic of the "front" half. The bottom half gets a bit wider as you go "deeper down", again roughly measured to 3.6 mm. So maybe 6.22 cm from the edge of controller, 4.45 cm from top?
The speaker itself is fairly big (1.2 cm diameter), so it will be fairly easy to hit, but the speakwr hole is only about a millimeter or two
I attached some pics with and without back. I tried my best to not move the camera, so maybe try interposing the images on top of each other, should give pretty accurate location of the speaker (covered by the yellow square tape)
Interesting stuff. The tinkerer in me wants a mini 3 even more now. It would be cool to make holes for two SMA ports on he top of the controller, and wire those to the internal connectors. Then you could just screw on any high gain antennas you wish. There are a ton available and depending on how "mobile" the operator needs to be there are some that are quite powerful, albeit bulky.
BTW, it looks like there might be pretty easy access to the control stick springs back there. A closer pic would help tell for sure, but if you want to firm them up you can just clip the spring length down a bit.
Hmm. I only see two of the springs but they look like they could be shortened easily. You can use two flat pliers to bend up a loop at the new length. Use the new loop to connect the spring and clip off the spring above it. You'd have to take the screws and retaining piece out to see if there is easy access to the spring for the other direction. Spring loaded mechanisms are tricky to disassemble and re-assemble but that one doesn't look overly complex.
EDIT - It's possible the same spring is used for both directions (likely actually) so you could probably just shorten those two visible springs and achieve your goal. ;)
yes, as you move left/right, the same spring gets lifted on the same side. Its 2 springs per whole joystick
Nice. Shouldn't be terribly hard to firm it up then. I'd start modestly with just a few coils at a time. Try one spring and see how much stiffer it gets and then use the same amount for the others. I'd go less than you think since it may become too firm after flying for a bit. Making them firmer should be easy, but you won't be able to go back the other way without replacing the springs.
Hi, here is another modified RC.
Unfortunately I'm not getting too much improvement over stock antenna.
all test done at 120m height
original antenna in town 600m and in field 1400m
Now with "6dbi" antennas in town 750m and in field 1750m.
I also tried "8dbi" antenna which is longer but result is worst than 6dbi.
Any suggestions?
Thanks
Reactions: Stach
That's some ugly antennae
:rolleyes:
Any suggestions?
Thanks
If I understand correctly, dB indicates how directional antenna is. Higher number (with otherwise identical specs) would mean better transmission at correct angle, but worse transmission at incorrect orientation.
I think your biggest issue is impedance matching. The amplifier in the remote (that sends signal to antenna) is designed with that specific antennas impedance in mind. Fitting hugely different antenna would mean impedance mismatch, so a lot of energy sent to antenna is reflected back to amplifier, instead of emitted into space.
Your best bet would be either of those:
- finding antenna with higher dB than original while maintaining similar impedance. That way you would have to be more careful to aim the remote precisely, but your range would improve.
- modifying the amplifier to accommodate your new antennas impedance.
So since I couldn't find a video to disassemble to DJI RC, I said to myself "how hard can it be anyways" and disassembled it.
I got you, man! I followed this thread, replaced my control stick module, and filmed it to share with y'all. It's not a full tear down, but here's what I did:
Ho everybody!
Last weekend I’ve had a “little incident”….
So I decided to disassemble the controller and finally I’ve resolved…..IMG_8661.jpeg
Any suggestions?
Thanks
Improving from 1400m to 1750m is surprisingly good for just changing the antenna from 3dbi to 6dbi. That's a 25% distance improvement, and while 6dbi sounds like double 3dbi, it's not that simple.
There's a couple of things that you might want to know about antennas:
First of all there's no free lunch. A passive (un-amplified) 6dbi antenna is not going to double your range by ANY stretch of the imagination. There could be some modest benefit increasing size and getting it farther away from the remote and into free air, and added directionality which I suspect is the biggest improvement. But the size needs to be appropriate for the wavelength, ie frequency.
Second, directional gain. Remember that signals decrease in amplitude by the square of the distance (inverse square law). An omnidirectional antenna radiates or receives equally in all directions. This is good where you have no way to orient the antenna in the direction it needs, but it's obviously less efficient because you have energy radiating directions that are unneeded. So for something like a 6 dbi antenna, it's going to be directional—that extra energy comes from somewhere, and it comes from the nulled direction—so, if you're not pointed correctly at the drone for your antenna's directionality, you're much more likely to lose contact.
Third, "db or not db, that is the question"... The internal antenna and the RC is a 3dbi antenna as I understand it. A 6dbi antenna is NOT going to double the effective strength or range. Doubling a 3dbi antenna would need (I think) a 12dbi to 15dbi antenna. Without amplification, that's going to have such a narrow beam, it's going to be hard to keep the controller pointed at it effectively.
Fourth, Signal polarization. Terrestrial Wi-Fi is most typically linear-vertically polarized. Looking at the photos of the internal antenna of the RC the antennas look like they are dual-horizontal+vertical. (some drones, and for instance FPV goggles are circularly polarized (CW or CCW)). For a vertically polarized signal if receive side is 45° off results in about a 3 db loss.
Fifth, impedance, the transmit and receive circuitry in the remote control is going to be designed for a specific impedance antenna, so any antennas that you yourself decide to modify it with, need to be of the same impedance as the circuit was designed for.
Sixth, the total TxRx system. It's not just the remote control after all, you also have the drone out there which has its own transmit and receive circuitry and its own transmit and receive antennas. I think some of the enterprise drones can have added Tx boost modules added (some of those drones are in the $15,000 + range...) For the consumer level Mavic/Mini etc, such an active mod is not just going to add weight, but also subtract from flight time, (not to mention questionable legality, your mileage may vary, different nations have different laws on that.)
Your setup: those look like the kind of antennas that are just on a home router. If they are, then they're probably just vertically polarized. Orientation can have an effect. Same is true for your 8dbi antennas, no I suspect that you got worse range with the 8dbi because they were substantially more directional, (read: narrower beam) and the drone was slipping out of the beam.
Where is the video signal port to the LCD panel? Is it using a ribbon cable?
I wonder if it is possible to add video out feature to the RC controller.
I found 2 PCB design on taobao that may work?
cata2k2k
