Droid Turbo 2
I'm using a phone that is not on the compatible list (HTC10).
It's working fine.
Re: Droid Turbo 2. Try the app and you will see.
Richard Powell, if you find it does not work, you can find a list of recommended and commonly used devices here.
My Droid Turbo works. It just barely fits in the controler arms though. Bottom of phone is just a bit to thick to fit in the grip of the arm, but if you're careful it won't fall out.
Q~
Q~
Are you meaning the Droid Turbo 2 or the original Turbo. I have both but the turbo 2 is the phone i use now.
My Droid Turbo Ballistic Nylon works great . I don't see why the Turbo 2 would not .
Did you figure out if it works well or not? I have the Turbo 2. Looking at the spec sheet, they are essentially the same. Turbo 2 has a faster processor and a little less battery life. Ordered my Mavic today. Hoping the Turbo 2 works.
robqwe
