Epson Moverio BT-35E
Epson Moverio does not work with Mavic Air 2 because DJI FLY requires at least Android 6, and Moverio Epson has Android 5. In fact, there is no DJI FLY app in the Epson store.
The op is referring to the BT-35e model which does not have the android controller like the BT-300, it uses a hDMI/USB-C input to display data from the sending device e.g. Smart Controller
[QUOTE = "lannes, post: 1023072, membru: 30451"]
Opțiunea se referă la modelul BT-35e care nu are controlerul android, cum ar fi BT-300, ci folosește o intrare hDMI / USB-C pentru a afișa date de pe dispozitivul de expediere, de exemplu, Smart Controller
[/CITAT]
You're right. I was referring to the BT-300.
Thx you all.
There is a small difference between the BT-35e and BT-300 in that with the BT-300 you actually see the cursor in the glasses so it is much easier to change menu settings and map view etc.
With the BT-35e you'll probably have to look down or through at the smart controller screen
BentenL
