Welcome from the Hampton Roads area of Virginia, USA. Next, I fly the
Mini 2 and I think it's a Great Little Drone and You'll have tons of fun with it…
We have a Member's Map in the Upper Right of the Title Bar.
mavicpilots.com
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current. Also, I do not know if what you have done is all that is required of you...
According to CAA, drones are allowed in the UK, subject to CAA regulations. Read on for more details.
drone-laws.com
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 2
www.dji.com
Happy, Safe and Legal Droning…
