Fcc permanent boost for ce countrys
Lip9571
uk
Hey all I've been reading about the boosts using fake gps then patching it so the disable_country= gets changed but the country gets set to zz even if fake GPS was used to set to usa
If I used the patch and set the country to US with telnet with a USB lan cable will its remember and keep us to give full power or revert to zz
hi thanks for the reply and sorry for the late reply. i finally managed to get the usb lan connector and after a few day test flying when i set the disable to country 1 and the country gets auto changed to zz i dont get a much range as if the country was set as us with fake gps with a fcc remote in a ce country.
so it looks like it will only boost the ce remotre to the full power of a ce remote and only give a little boost to the fcc in a ce country
on a side note if i come out of fcc mode i can just set it back to US without using fakegps anymore
mr1ss5 RC with "country=ZZ" is much more low power then "country disable=0". In ce country
Eliassmith02
