Feelworld monitor
Ok, thanks PAW, I’m looking at the LUT11S 10.1“ and interested to know about the battery life for that size As well
Yes it does. Pretty similar to what you have there. A little bigger. It is heavy and I pretty much only use it when I have observers in use844B326B-96A2-4954-BE64-BD6B5633715A.jpeg
Reactions: GadgetGuy
I believe @GadgetGuy uses the 10" Feelworld
I do, as well as the 7”. The battery life completely depends upon the number and capacity of the batteries clipped onto the back. There are two slots, but even one alone works. There are thinner, lesser capacity batteries and fatter higher capacity batteries available, so it's a compromise between battery weight during use and screen time. One can also add and swap batteries as needed to keep the screen light during use. Unlike the drone, you can swap batteries in flight, if they are used up. Lastly, the setup also takes a DC input from the included AC adapter for continuous use when AC power is available.
msporting
