First-timer Hype!
Welcome to the forum! :)
Greetings from Birmingham Alabama USA, welcome to the forum! We look forward to hearing from you.
Having a blast test flying my Mini 3 Pro,
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Oregon, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Hello from Minnesota and welcome to the Forum....Congratulations on your Mavic Mini 3 Pro...There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safely and fly smartly representing all of us drone hobbyist well.
seaphotos
