Did DJI fix the issue where you have to tap focus on the screen every time you fly the Mavic, or is that still required?
It WAS an issue if you forget to tap focus and then your video is blurry.
So did they fix that or not?
The C2 button does a Center Focus. However if you are flying without a screen then surely video or photography are not the reason you are up in the air right, you cannot see what the camera is pointing at anyway lol.I was also curious on this because if you choose to fly without a tablet/phone and only the controller, how would you tap to focus unless it would autofocus
If your car runs out of gas because forget to fill it up, is there an issue with your car? Or is it just user error?
Still user error though as time would tell you that your gauge is inaccurate right just as footage would tell you that you did not focusDepends if your gas gauge is accurate
There was nothing to change in the app settings after an update for me. It just started to auto focus on its' own when I pressed the record button.I have the latest firmware but when I hit record it does not focus automatically. Is there a setting that has to be turned on?
Did you update the firmware on your vehicles ECU first before it ran out of gas? LOLIf your car runs out of gas because forget to fill it up, is there an issue with your car? Or is it just user error?
