Gimbal shakes once slowing down / going forward
jakub.spe
Poland
Hi All,
I have recently experienced weird gimbal shakes when I fly ahead or stop instantly. Before, such small gimbal movements could be experienced in sport mode but never in normal mode as it is now. The weather conditions were rather normal, no exceptional strong winds. Any idea if that could be gimbal motor problem?
Thanks!
May be some changes have been made to the new firmware ? You may fall back to the older-version firmware and see if the phenomenon will go away.
nope, follow mode as usual
Hello ! Did you find any answer ? The same problem happened to me today , after several flights with no problem/incidents , no firmware changing ...Follow mode as usual , manual or sport mode , same behavior - when I stop in flight , the video image moved up and down suddenly , for a fraction of second , then in echilibrium again...
zenbookwriting
