Green tint
Airtex
Every time I fly my mavic pro using iPad and view map screen, it appears with a green tint. How do I fly with no tint?
Thanks.
Airtex
There are 3 choices for map view. The first one that appears once you touch the map icon will be a standard map view, the 2nd and 3rd are satellite views from which ever map provider you initially selected, Google or Apple. I believe you are seeing one of the satellite views.
Got a screenshot so we can see what you're describing?
Sounds like you have no internet connection so it can't load the actual map content and just shows the default background.
I feel like a dope, but I panned out on my view, and the green/yellow tint is the last circle of caution for a nearby airport. Is there anyway to remove these concentric circles related to the airport? I fly on the caution (mostly in my back yard when it comes up and I'm tweaking settings.) Then, of course, when I fly far away from the airport no tint. Thanks, guys.
It will also show the distance limit in a green circle. E.g. if you have your distance limit set to 500m it will show a green circle with a 500m radius. You can then see when your aircraft is reaching the 500m limit. If you zoom out you can see your 500m limit 360 degrees.
dipshot
