Greetings Drone Pilots!
retleo121
Ohio
Hello! Noob drone operator (won't call myself a "Pilot" quite yet!) here.
As the name suggests, I survived nearly 25 years working in two states, retired, and am leading a much quieter life now. I was also a USN submariner and continued on to retire from the reserves as a CPO with 24 years.
I flew single engine aircraft at 16 years old, the age of which I attribute to NOT getting my full private pilots license and/or pursuing a career in flying. I was actually "bored" with flying, believe it or not! They didn't bring out drones at the agencies I worked for until after I retired, so drone flying was often just a thought to me.
Drone flying became reality when I told my wife that I'd get my main Christmas gift for myself this year. Does she know how much it cost? I plead the 5th. But I purchased a Mini 3 Pro and have had it out around 10 times as of the time of this post. I posted in a thread dedicated to fear of heights while flying, so if you are so inclined, please respond to that one here.
I am absolutely amazed at the technology in today's drones. They make it pretty dog-gone user friendly, and I hope that the advice I gain from the drone pilots in this forum help me get the most out of my flying experience. Thanks!
Welcome to the forum! :)
Welcome to the MavicPilots forum. Enjoy safe and happy flying, and have an exciting 2024!
Your on the top of my list for awesome intros. Thumbswayup
I looked at you other post Cessna 150 is the smallest?
When my dad +26 to my age got his pilot license we took a flight.
We both are fairly large guys still in the 6' range. I couldn't get my door closed because I hitting his shoulder he had open his door so I could close mine.:rolleyes:
Anyways, he still files as a copilot because of insurance.
Rod ..
Welcome to the forum! Greetings from Canada! I am a newbie apprentice drone pilot too.
Welcome from Vero Beach Florida. You are a pilot, you've already flown about 10 times and survived. You will soon become an expert pilot.
@retleo121 Welcome and THANK YOU FOR YOUR SERVICE!!
Noob drone operator
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Ohio, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
ehj147
