Greetings From NW Oklahoma
Kirk T
Greetings from northwest Oklahoma. I am retired from 34 years in the fire service. I have been around drones quite a bit, but never have I owned or piloted one. The interest has been there for quite some time and now that I am retired. I would like to pursue those interests. I have an acreage with Creeks and wildlife which I feel is a good place to get started. I have been doing some construction work since retired. I also enjoy Overlanding. This seems like a very good place to learn. and seek help with my drone interests.
Hello from the Crossroads of America Kirk T.
Nice to meet you Kirk. 🤝
You can take the TRUST test now to keep a copy with you when you fly.
It's a free no fail test that's easy to take that covers the basics of flying a drone.
Depending on what aircraft you purchase, it may need to be registered with the FAA.
If you live near an airport or other restricted areas, you can get a heads up with the B4UFLY app and apply for permission in some cases.
Good luck, have fun, and welcome to the Forum. :cool:
Thank you for the help and links. I plan to be responsible and do things correctly. I appreciate your welcome!
There are a couple of Legal Things you may need to do…
One of the members, @MA2 317, has already given you the heads up on things you will have to do if you do buy a drone, so I will not rehash it here…
But, if you are thinking about the DJI 3 Pro, then checkout YouTube and watch a lot of videos on that and other drones you might be interested in. The hardest part is deciding what you want, what you need, and whet you can afford…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Oklahoma, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Since you have never flown Drones before, here is some Good Old Fashion Advice to get you started…
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Thank you for the welcome and the good sound advise.
Welcome to the forum! :)
Welcome to the forum. We look forward to your participation and your view of the world.
I have taken the TRUST test and downloaded the B4UFLY app. I have a question after looking at the B4UFLY app. I Live near Alva Regional Airport and not far from our hospital helipad. My acreage is 18 miles in the middle of nowhere and I assumed that would be the only place I could fly. But after looking at the B4UFLY app there are no restrictions at my residence. The green tab at the bottom says "Clear for Takeoff No Active Advisories. Maintain Situational Awareness." I still plan to do my learning at my remote location. What are your thoughts on some limited flying at my home? I certainly don't want to cause a problem or alarm. I haven't purchased a drone yet but want to be knowledgeable beforehand. I am also very interested in getting 107 certification. any pointers for that process would be appreciated. Thanks to all for the welcome. Kirk
You should be safe to fly from your home to practice.
Some new pilots like to try and fly inside, which is ok, but it opens a can of worms not worth dealing with as a new owner..
Lack of GPS, prop wash, etc. can end a first flight fast if flown inside and not experienced.
Check the local ordinances about flights in your area such as parks, etc.
In my area, State parks, and county parks don't allow drones. The city parks do allow drones.
The FAA governs the airspace but not the property below it so you might have restrictions when trying to launch / land from the property.
I started flying in my back yard in 2017 but I go to a remote location now just so I don't annoy the neighbors and to maintain VLOS during the flight.
The first few flights were simple as I would launch, hover, and study the telemetry on the screen as I would move the drone and go through the menus to check out the information provided.
The Mavic 3 Pro is an expensive first drone. I would recommend the Mini 4 Pro, or the cheaper Mini 3 Pro. Here are the reasons.
1. Mavic 3 Pro has a great camera, but you're not likely needing theater quality 4K video, nor would I expect you to be equipped with a computer and editing software to edit your videos. It's sounds like you don't expect to post any online for others to see, but I may be wrong. Mavic 3 Pro is really for a professional, way overkill for your purposes of learning.
2. I've been flying DJI craft for 8yrs now. Started with P3P in 2015, then P4P, then Mavic, then Mavic 2, Mavic 3, Air 2S, Mini 2, and Mini 3 Pro. Yes, DJI has lots of my money, my addiction. I've edited and posted on YT over 200 videos. Although I have 4 DJI drones today, my go to drone is the Mini 3 Pro. It's adequate for my needs, it shoots 4K, it's small, it's light, and it's quiet. The only downside is it's not as capable in high winds, but I don't fly when it's windy, I prefer nice calm sunny days to fly, regardless of the drone I'm flying. The golden hour a 4pm is my preference.
3. Mini 3 Pro comes with the DJI RC controller with a built in screen. This is super convenient versus using your phone or iPad for display. Less cables, less items to charge, and more compact. With the DJI RC it's super quick to launch, which is key IMO, the main reason it's my go to drone.
4. If you make a mistake and crash, it's not as big of loss. The cost is key for a beginner. I suggest you start small and learn the software and control functions in your first year. Then you can confidently move on to something bigger, if you really think you need it. The Mini 3 Pro is currently $840 at Costco, or $909 from DJI.
cht6688
