Hello from the new guy in Portland, OR!
RevSteve
Portland OR
I've been interested in drones for a while, and now that I'm retired I finally have time to pursue it. I started with a Mini SE, but only flew that a few times before I got a deal on a Mini 2 last month. Maybe I'll put the Mini SE on eBay. Anyway, I'm having fun developing my skills and flying around the neighborhood. I hope to find some wide open spaces to fly once the weather improves. So glad I found this group. You seem like a fun bunch! 😁
Welcome from all the way from over here in Savannah, GA!
You really did find a great spot. Honestly, its the only spot! Good for you! Please share some pics and vids....
Welcome to the forum. We look forward to your participation and your view of the world.
Hello from the Crossroads of America RevSteve
Welcome to the Forum. :cool:
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Both of your Drones weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drones.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Oregon, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 2 and the SE, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Get thee to Cannon Beach and environs. Restricted air space (1000' from nesting areas) to nicest boulders. Get there just before sunrise and should have no problem.
See attached non-drone picture for view of landscape.
I used to live on Livingston Mountain north of Camas, WA. There is a park dedicated to dirt bikes in wooded area there that would afford great views of Mt.Hood. Last year there was a big fire near there that likely created some open area. I would check that out if I still lived there. Have fun!
Welcome from across the River!
PilotOne
