Hello from a new(ish) member in Essex, England.
Feek
Essex, Blighty.
Hi all,
I joined when I bought my Mini 2 a few years ago but it only got a few flights (I bought it for a specific purpose) and have since dug it out and decided I need to fly more, I took it out in the garden and managed to hit a wall (don't ask), repaired it and now I'm back, itching to fly.
I've made one flight since fixing it, that went OK and now I've bought some ND filters. Really keen for the weather to improve so I can go flying again.
I thought it would be nice to check in and now, having done that, I'm going to have a good look around the forum.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you have flown Drones before, you still do not know how… Hence the "wll incident… So here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
Reactions: old man mavic
Welcome to the forum. We look forward to your participation and your view of the world.
Welcome back!
volidas
