New member.
Ohio
Hello from southeast Ohio. Thank you for letting me join your group. I’m not a drone pilot yet, but I would like to be if I can find a drone that works properly and I can afford it. I bought a Holy Stone HS720 and did all of the FAA stuff including the TRUST test. It turns out that this drone is so unreliable that I’m not even going to try to fly it, I’ll just hang it on a wall or trash it. I thought I would join this group and see if DJI has anything that works properly and might still be affordable. Thank you again for letting me in your group!
From CA to OH - Thanks for joining us @ MP!
Similar story here. Bought a Potensic drone to see if I would like flying, which I did. Upgraged to a Mini 2. As @Cooner stated, a big difference in performance, in video.
I would suggest looking a Mini 2, 3, 4. Usually the cost is a bit lower, but I would also suggest a Fly-more kit. It gives you more batteries, a charging hub and case to store it all in. In the long run it saves you $$ because it's bundled. Whatever you choose, it should bring you lots of enjoyment.
Thank you for your reply. I will certainly follow up on your suggestions!
Welcome to the forum! :)
Ad you probably know, MavicPilots is predominately a DJI Drone Site and if you scrool all the way to bottom of this web page, you will see the other Sister Web Sites that are associated with us, ion case you decide on a drone other than a DJI…
I fly the Mini 2 and I've had it for about 2-years and it still flies great. Many of the members have stories of their drones having flown hundreds, and even thousands of miles with issues. DJI drones generally cost more, but as you know that does not always mean you get a better product, but I think you will find that DJI is one of those products that will serve you well, and if there are any issues, DJI Support is quick to respond and helpful to the extreme… I know thee will always be some with horror stories, but I don't have any and if you search our database, I think you'll agree…
Any case, once again Welcome, and perhaps the advice below will make for a fun flying experience for you (when you get airborne…).
Since you live in Ohio, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
in the mean time, while you decided on your next Drone, in case you decide to pull ot that HolyStone, here is some Good Old Fashion Advice…
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Welcome from Vero Beach, Florida. DJI has an excellent line of drones. All of them are good and it just depends on your budget and how you intend on using it.
There is a classified forum here that you might watch. Check threads that discuss the idea of Binding the drone to the controller. If you buy a used drone that is bound to the controller under another person's account (if they have not wiped it out) you will run into trouble down the road. It's important the seller remove their account from the drone. You're welcome...it was a close call but you squeaked in :). North Pole, Alaska here.
Welcome to the forum from the beautiful woods of Maine!
There’s no problem starting off slowly, better chance of not crashing. There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
Thanks for the reply and all of the information, I will take it all to heart!
Thanks, I had already discovered the problem of bound drones. I will be buying from dji directly, probably.👍
Reactions: MotoSavy and RodPad
anton13
