Hello from New Hampshire, USA
coachnh
new hampshire
Hello everyone,
I am a new owner of a Mavic Pro 1 I bought at a very reasonable price. It came with a fly more package which included 3 batteries, controller, single charger, four way block charger and a three way Mavic charger, extra propellers, landing pad and other stuff.
I was wondering if anyone here might know if this Drone will ever have an update to the firmware to include Remote ID or is it too old for DJI to be concerned with? Just wondering if I wait it out or do I bite the bullet and buy a module? I only fly for recreation.
Thanks for letting me join this group.
Hello from the Crossroads of America coachnh.
I'm in the same situation.
Hopefully the Mavic Air 2 will receive an update.
There's been some chatter here that the Mavics may get an upgrade, but it will be after the September deadline and before the end of the year 2023.
Fingers crossed 🤞.
Welcome to the Forum. :cool:
Welcome to the forum! :)
DJI did add support for the Mavic Pro Platinum, so anything is possible I guess.
Going straight to the source is prudent. The FAA rescinded the Mavic Pro Platinum: UAS Declaration of Compliance
Seems DJI had an ooopsie.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in New Hampshire, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic Pro, including the User Manual.
And some more…
Fly On and Fly Safe…
Photogeezer
