Hello from NC
Rick Fast
North Carolina
Just joining up after having some issues with the new "NFZ" restriction on my Mavic 2 Pro. Never had that before and trying to get it straightened out. B4uFLY says I'm ok to fly, and I filled in the flight plan to stop the resptriction, but I'm using a mini pad with no cellular sim and I wonder if that is what is stopping my from getting approved. I have using my phone The screen is too small for my beady little eyes to see outside. Any one have any experience with this?
Welcome to the forum! :)
What do you see on the screen that seems to be preventing you from flying?
NFZ And Iknow I ampretty much directly under the Landing/approach path to an airport 4 miles away, but it looks like I should be able to respond to B4Ufly on my cell phone, but it doesn't seem to get to my controller/minipad. Though I did open "HotSpot" on my cell phone and connected the minipad, so it has a connection. Just not sure if that is enough!
Reactions: LoudThunder
B4UFLY does not integrate with DJI's applications in any way. You'll need to request an unlock from DJI here in order to fly in an NFZ.
And this one might be obvious, but getting an unlock from DJI does not mean it's legal to fly in an NFZ. That will just allow the drone to take off in locations where it normally cannot fly.
Thanks, it looks like that did it!!
From the issues you are having, it sounds like you are a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in North Carolina, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Fly On and Fly Safe…
Hello from Minnesota and welcome to the Forum and congratulations on getting things figured out....as you know there's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use...Remember to always Fly safely and fly smartly representing all of us drone hobbyist well.
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your questions and I’m sure you’ll get a quick response! Fly safe and stay safe!
Welcome to the forum. We look forward to your participation and your view of the world.
Welcome to the forum from the beautiful Rocky Mountains of Colorado! Happy and safe flying!
Hi Rick. I am in eastern NC around Greenville. Are you in the area?
Reactions: MA2 317
InspectorTom
