Greetings from Garfield35
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . ?
Hi Garfield35 Welcome to Mavic Pilots.
New flyer advice,
Wide open space.
Slow & easy
Power-lines & trees are evil.
Don't expect RTH (Return To Home) to save you especially if you are under trees.
Don't forget to read the manual ;)
Download Air manual HERE
You want an SD card that is U3 for 4K
Most of all have FUN
Welcome to the forum! :)
New pilot with about 1 hour of flight time (Mavic Air).
Here are some things to help you get started with your Mavic Air:
  • The current Mavic Air manual can be downloaded here (it doesn't come in the box). Other important documents can be found on the Mavic Air downloads page.
  • Check out this getting started guide for some tips not found in the Mavic Air manual.
  • This video covers all the basics of the Mavic Air.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Hi All! New pilot with about 1 hour of flight time (Mavic Air). Very fortunate to have a friend who is quite experienced to help get me off the ground. Look forward to learning more here on these forums.
Garfield35
Welcome to Mavic Pilots from Dayton Ohio USA! Enjoy your new Mavic Air, Fly safe and have fun!
ScottLoucks
