Greetings from Kenna, La.
Greetings from Birmingham Alabama USA, welcome to the forum!
Hello from the Crossroads of America Max1014.
Glad to see you're on the up & up with the registration and TRUST test. 👍
Welcome to the Forum. 😎
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hello all, kind of new to drones. I have a Air 2s. I have gotten my Trust certificate and Faa registration.
Glad you've done all the legal stuff, now you can have fun…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Louisiana, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy Droning…
Welcome to the forum! :)
tomi503
