New from Cypress, TX
timc_drone
Houston
Hello All! Long time drone flyer but have been inactive since COVID. Looking forward to getting back into Drones and all the new tech.
Paid $5 and got my Small UAS Certificate of Registration FAA number and received my TRUST certificate after passing the test. Am I missing anything else?
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Even though you have flown Drones before, here is some Good Old Fashion Advice…
Tell us what you are flying and we might be able to hook you up with some great links…
Fly On and Fly Safe…
Thanks for all the helpful tips, much appreciated.
Greetings mate, welcome to the forum from the outback of Australia.
Regards
Welcome from Brenham, just up 290 from Cypress. Where do you like to fly in your area?
I mostly fly in green land and trees on Grand Parkway 99, open area with no one around. In Bridgeland there are also scenic places and trails worth viewing. My previous drones did not have the range the DJI ones have now a days so I'm exicited to take my mini's on vacation. I can't wait for blue bonnet season in Brenham, we have some great pictures of the kids from above.
Sounds like nice flying. I drive thru Bridgeland sometimes, when I take 10/199 instead of 290. Lots of wide open spaces.
I've got a list of people on this forum who have requested status updates on wildflower season. I will post when they start blooming, and add you to the list.
Thanks Astrohip, much appreciated for adding me to your list.
Welcome to the forum! :)
dseyna
