Greetings from Marietta, GA
Welcome to the forum. I can feel your excitement. Mini 3 pro is a great drone to play with. If you happen to look for a handy case to carry and protect it, check out our MM330 hard case. Enjoy!
Hello from the Crossroads of America russpury.
Cheap drones are easy to crash.
DJI drones are easy to fly.
Welcome to the Forum. :cool:
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to Mavic Pilots! :)Enjoy the forum!Thumbswayup
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum from Georgia. We look forward to your participation and your view of the world.
New DJI Mini 3 pro, my second drone. First was a toy that I never could get the hang of flying.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and if you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Georgia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
Welcome to the forum! We know the Marietta, GA area well and have a number of contract pilots around there. If we can ever do anything for you, let us know.
New DJI Mini 3 pro, my second drone. First was a toy that I never could get the hang of flying. This one is a dream, IMHO. Having a blast, even if I live under Dobbins airport.
Hi Cliff,
I live in East Cobb. If interested, let's get together and fly.
Welcome to the forum! :)
Reactions: LoudThunder
Kasperskyy
