Greetings from New Mexico
Welcome to the forum! :)
Hi all,
I'm very new to the drone photography world with my Mini 3 Pro. I started to get into some basic still photography while on contract in Alaska and liked it. Hoping this opens a new creative world for me.
Hi all,
Welcome from Cambridge, UK
Welcome to the forum from the beautiful woods of Maine! There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your question and I’m sure you’ll get a quick response! Fly safe and stay safe!
Hi all,
Welcome to the Forum. What part of NM? I will be there for about 6 weeks in the early spring.
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama USA, welcome to the forum!
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you intend to do more than post your photos on your Social Media, you might consider acquiring your Part 107 License, here is a link to get you going…
Since you live in New Mexico, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy Droning…
Hi all,
Welcome from Brisbane Australia, I am finding the creative advantages huge, more than I even thought, flying around it is amazing how the light falls onto objects differently even without moving much
ralph.smith.mckenzie@gmai
