Greetings from Northern California
Rotofiend
California, USA
Hello everyone,
Glad to be here. Bought a Mini 2 when it released back in 2020, flew it a lot only to stop once I left for college. I've recently picked up the hobby again and have rediscovered the joy of flying.
Looking forward to learning the ropes of droning again. It's great to see such an active and welcoming community dedicated to these machines.
Welcome to the forum! :)
Hello everyone,
Welcome! I'm right down the road in Savannah.. Hope to see some of your posts around here... I love flying but I'm always trying to capture "that shot."
Looking forward to seeing some of your photography... :)
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California , there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
Keith J
