Greetings from south central NC!
Wolfpack
Mount Ulla, NC
Admittedly, I am a drone noob, but I have the luxury of having a SIL who is a skilled drone flyer and who just purchased the new DJI Mini 3. I had been wanting a drone for some time and about pulled the trigger on a Mini 2 not too long ago, but when my SIL said I might want to wait and see his Mini 3, I'm glad I did. Admittedly, some of the comments about the poor range issue showing up on some of the Mini 3's are a bit concerning, but I hope DJI can fix this issue with firmware updates. In the meantime, I will be placing an order soon and look forward to any insight I might gain from this community. Thanks for letting me join.
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum. We look forward to your participation and your view of the world.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Even in North Carolina, there are a couple of Legal Things you may need to do…
You will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Link to the Pilot Institute Web Site (FREE…)
Link to the FAADroneZone (Optional for Drones under 250-Grams…)
Since you live in North Carolina, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
When you do get your own drone, do not let the excitement of the moment get the best of you. When you are going out to fly, do it slowly and deliberately. Get used to a set procedure and even practice it.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum. Hope you enjoy flying mini 3 pro which is great. The range issue, as far as I know, has been addressed in the latest firmware upgrade. If you need a handy case to take your mini 3 out, check our MM330 waterproof hard case. Have fun.
Welcome to the forum! :)
WELCOME !!!!!!
Welcome to the best drone forum around, you will find the people in here to be very friendly and helpful. I have quite a few drones, and recently added the Mini 3 Pro to my inventory, I can confirm that the range issue is fixed. There's still a few bugs, particularly with focus hoping, but I'm sure they'll be ironed out with time. Happy flying!
WELCOME to the forum from the mountains of NC :)
Welcome, enjoy and fly safely.
Welcome to the forum from the dry lakeless hills of Lake City FL. An irony... I know. If lakes grew here as much as your knowledge will, Lake City would become an ocean. ;)
Welcome again!
peehead
