Greetings from the UK!
Welcome to our forum, from Hauptmann, in North Texas!
Isn't it great to be able to get photos and videos you could only dream of before? I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro.
We have over 150,000 members who enjoy helping each other get the most out of our hobby. Can't beat the price, either. Most of the questions you'll have have already been addressed, and are easy to search. If you have NEW questions, just ask!
Thanks for joining our ranks!
Rich R (aka Hauptmann)
100%! When I first got it, I was super captious and reluctant to fly more than a few metres from the ground, but the amazing views are just too good.. that and my brain is still having trouble trusting the connection over more than like 10 - 20 meters 😂
Got a Mavic Mini (1) back in 2020 and near enough forgot about it till recently.
Since it has been a while since you've flown and the laws may have changed and since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even though you have flown your Drone before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini, including the User Manual.
Fly On and Fly Safe…
I've come to this hobby from the RC Heli pilot side. Safe to say preflight caution is seared into my brain fully. Transmitter first, check systems, etc 😛
I've never flown a traditional RC aircraft, but have followed the same procedure after reading a post about RC communication.
It basically said to turn on the controller first to establish a frequency and then turn the aircraft on to connect.
As I understand, this helps eliminate the possibility of other RC pilots at an airfield connecting to your aircraft when it's on and waiting for the controller to connect. They may have the same frequency and connect to your aircraft?
There's been discussions in the past about what to turn on first with the DJI, remote or aircraft.
I guess it doesn't matter with today's technology, but there's something about old school rules.
It's to prevent flyaways too - older models with cruder hardware could pick up background noise and interpret it as a radio signal.
Kitkat
