Greetings From Vancouver WA by way of SoCal (Corona)
Finally got my first Drone (Air 3)......Wow...Why did I wait so long?
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Fly On and Fly Safe…
Hello from the Crossroads of America Xavier6162.
Mine was the DJI SPARK in 2017 and currently flying the "old" Mavic Air 2. :)
Make sure it's registered with the FAA and you have taken the TRUST test to keep with you when you fly.
Have fun with your new "toy" and welcome to the Forum. :cool:
Thanks for the advice. Did the Trust and Registration before the fist flight. Registration already taped to the Drone. Thank you about adding my phone number too. Working on my 107 via the Pilot Institute. 1/3 through the course as of today.
Welcome to the forum! :)
Been around for awhile. Finally got my first Drone (Air 3)......Wow...Why did I wait so long?
zenbookwriting
