Grid photogrammetry simplest tool for litchi waypoints
I haven't flown a Litchi mission with it yet, but it looks like very good work. The web interface is clean, simple, and easy to use. I appreciate all the work you did to create this and your generosity in sharing it.
Mille gracias.
Reactions: afbayonac
New Feature, I add support for mobile.
But litchi not has a method to upload waypoints direct to app 😔.
When I add to Litchi mission, how is it knowing where to take the frames captures. For example when I imported a CSV that would capture 30 frames, I'm only seeing 6 waypoints imported into Litchi with no instructions on capturing frames. The only instructions that seems to carry over is camera pitch angle, and the end points to travel.
Edit : is the "interval" in feet marked on the waypoints individually the photo capture calculated ? Edit 2 : yes it is.
Omni_Aerial
