I have a
DJI Mini 2, very happy with it
mavicpilots.com
Since you live in France, there are specific laws and rules for you to follow, please check to ensure these are current.
According to FCAA, drones are allowed in France, subject to FCAA and EASA regulations. Read on for details.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the
Mini 2, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 2
www.dji.com
Happy Droning…
