I’m new here and I’ve just purchased a Mavic Air drone
mavicpilots.com
Since you live in Romania, there are specific laws and rules for you to follow, please check to ensure these are current.
According to AACR, drones are allowed in Romania, subject to AACR and EASA regulations. Read on for details.
drone-laws.com
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air, including the User Manual.
At DJI Download Center, Learn aboutMavic Air
www.dji.com
Happy Droning…
