Hello from Birmingham, UK
Hi I’m about to embark on my first drone purchase…..yes you’ve guessed it the Mini Pro 3. I’ve come here to seek words of wisdom on what package I should go for and any other drone tips.
Greetings from Birmingham "Alabama", welcome to the forum!
Welcome to the forum. You came to the right place. Check the specific forum for the Mini 3 and you will get all sorts of feedback. Wish you well. We look forward to your participation and your view of the world.
Hello from the Crossroads of America boybrown.
Good choice.
Welcome to the Forum. :cool:
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome to the forum. Be sure to get the Mini 3 Pro DJI RC combo and you won't regret. It's fun communicating with other pilots here. Mini 3 pro is a great drone to play with. If you happen to look for a handy case to carry and protect it, check out our MM330 hard case. Enjoy!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum! :)
Reactions: MA2 317 and GFields
jigjjihhwohekjgh2857
