Hello hello
Greetings from Birmingham Alabama USA, welcome to the forum! We look forward to hearing
Hi,
I’m Mark, from the UK.
New to drones, just purchased the DJI Mini 3 Pro. Hand had it about a month but due to continued poor wet weather haven’t been able to get it in the air yet. So been digesting YouTube set up videos.
Looking forward to interacting with people on here and gaining wisdom.
Mark
Welcome to you Mark from Houston, Texas. You found a good place to be then.
Hello from the Crossroads of America Mrktn
Nice to meet you Mark. 🤝
Welcome to the Forum. :cool:
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum from Hauptmann in North Texas!
You made a great choice in the Mini 3 Pro--totally the one to get! With its sub 250 gram weight, it is not subject to many of the restrictions imposed on heavier drones. You'll love the flexibility of vantage points an aerial camera platform affords. Hope you get to fly soon--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro, like yours.
Our more than 150,000 members worldwide enjoy helping each other get the most out of our hobby. Many of the questions you'll have will have already been addressed, and are easy to search. New questions? Just ask!
Other Mini 3 Pro owners have had range issues. Our members have found fixes for that problem.
Glad to have you with us!
Rich R (aka Hauptmann)
p.s. Be sure to follow GFields' and LoudThunder's advice.
Welcome to the forum! :)
peehead
