Hello from France
I was looking for a solution to avoid charging my android phone when it is plug on the controller.
[/QUOTE
welcome to the forum,it is something that happens with all android devices im afraid
Welcome to the forum! Unfortunately on the Android app version, there is no setting to stop charging the mobile device, as that would sever the connection altogether (Google design limitation).
Welcome to the forum.
Don't be shy and ask anything if you can't find it by searching . ?
As I understand the problem can not be solved at software level by dji, because the only app that allow to stop charging requires root level! So there is only one solution at this time is hardware, but the controller are already existing. As someone else explain in another thread it should modify the connexion. I haven't found on internet a cable that stop charging. There are only cable that stop data ?.
As some told me here, may be it is not a big deal to fly 3 batteries.
On ios is it a parameter in the dji app?
Reactions: mrjohnc1
Welcome to the forum! :)
Ron613
