Hello from Granbury TX
Welcome to the forum. We look forward to your participation and more of your view of the world.
Welcome to our forum, from Hauptmann, in Hurst, Texas!
You'll love the flexibility of vantage points an aerial camera platform affords--you'll get shots and videos you could only dream of before! I fly a Mavic 2 Pro now, but will soon be upgrading to the Mini 3 Pro.
We have over 150,000 members—many, many from North Texas--who enjoy helping each other get the most out of our hobby. Most of the questions you'll have have already been addressed, and are easy to search. If you have NEW questions, just ask!
I attached a couple of links below, which will make learning piloting and photo/video skills easy.
Glad to have you with us!
Just got a DJI Mini Pro 3
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Drone weighs less than 250-grams (0.55 pounds) and while you are flying flying light and under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Texas, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Welcome to the forum! :)
DrDew
