Hello from Madrid, Spain
Sanmer
Madrid, Spain
Hi there!
I still consider myself a newbie pilot although I have been flying a Mavic Pro since 2018.
I recently had my first crash because of the drone flying out of control, but fortunately it got tangled in a tree and I was able to reach it with minor damage on the propellers.
I will post the detailed information in the dedicated section.
Cheers!
Welcome to the forum! :)
Since you wrote that you consider yourself a "newbie" even with 5-years "experience" I will pass on some old wisdom onto you that I was taught. My supervisor told me this when I was selected for promotion ahead of a lot of more senior personnel.
"When someone asks you why you were promoted with only 4-years experience when they have 20-years experience, you tell them: 'I may have only 4-years experience, but your experience is also only 4-years, but it has taken you 5-times longer to learn it!'…"
So, I will give you the benefit of my old wisdom…
Since you live in Spain, there are specific laws and rules for you to follow, please check to ensure these are current.
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mavic Pro, including the User Manual.
Fly On and Fly Safe…
bullet_magnet
