Hello, from Melbourne Australia
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Welcome back to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. As dirkclod said, search the forum (use key words) and if you don’t find an answer, post your question and I’m sure you’ll get a quick response! Fly safe and stay safe!
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in Australia, there are specific laws and rules for you to follow, please check to ensure these are current.
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Happy, Safe and Legal Droning…
Welcome to the forum! :)
PilotOne
