Hello from Plymouth UK not MA!!!
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum! :)
Just got my DJI mini 2 with combo pack yesterday. Hoping to pick up some hints tips and tricks.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in the UK (Not Masscults), there are specific laws and rules for you to follow, please check to ensure these are current.
Be Very Careful about flying that new baby in a house. It's real easy to give it too much throttle and bounce it off the ceiling, and do not hover or fly near any walls, the down-draft of the prop wash will cause the drone to drift towards the wall and destroy those props…
Here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy, Safe and Legal Droning…
Thank you. I have watched endless YouTube videos before I decided on one only to find out a lad a work has the same one lol
I won’t be flying it indoors anymore until I can get outside
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
So took it out tonight with about an hour of light left. Was about a 20mph wind which I was a bit anxious about but my god it’s a stable drone from ground to 400ft. I will have to try getting used to looking more at my screen rather than the drone itself and I have to remember that it is capable of going more than a couple of hundred ft away from me. I guess it just comes with experience.
The 4K camera is amazing
palaiouras
