Hello From Scotand
Welcome from the Hampton Roads area of Virginia, USA. So glad you could join us. As I wrote earlier, on the other web site, you will find lots of friends here and I see you've got a good start…
We have a Member's Map in the Upper Right of the Title Bar. Click on "Members" and then Click on "Member's Map…" Check it out and you might find some new flying friends.
Since you live in the UK, there are specific laws and rules for you to follow, please check to ensure these are current.
As a Newbie, here is some Good Old Fashion Advice…
Plug in your phone/tablet into your controller; turn on the Controller and DJI Fly App (if it does not start on its own…). On the Drone, open the front legs, then open the back legs, and then remove the Gimbal Cover.
Lift off, 6 feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, "Home point Updated."
Below is the link to all of the downloads offered by DJI for the Mini 3 Pro, including the User Manual.
Fly On and Fly Safe…
Thank you Loud Thunder. Some very good advice there, much appreciated. A good chunk of it I have already put into operation and the rest will be taken note of.
Perhaps you can help me, Ladyc? We’re planning a road trip in Scotland next June for a fortnight. What areas have drone rules and which don’t? I fly a Mav3C which may require a license in which case I have a Mini2 but I’m hoping you have some pointers. Thanks in advance. Ted
I'll give you a link to a summarised section of the Scottish Access code 2003 below which might help. As you will see it gives access for recreation and educational purposes amongst other things, although it doesn't mention drones specifically they are recreational so you can fly in most places. I'll give you a link to the CAA rules which will give more specific sites where you can't fly.
If I can help in any way by organising an itinerary I would be pleased to be of assistance if you let me know what type of things you like to see and do.
anton13
