Hello from South Africa
Greetings from Birmingham Alabama USA, welcome to the forum!
Hello from the Crossroads of America Ruan.
Welcome to the Forum. :cool:
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hello everyone. New pilot here from SA. Just bought my first Air 2S and looking forward to learning as much as I can about it.
Hello and welcome from sunny Savannah, GA! Enjoy your stay and I hope you find this forum as informative and entertaining as I do!
Since you live in South Africa, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2s, including the User Manual.
Happy Droning…
Welcome to the forum! :)
phoenix_00002
