Hello from South Carolina
Welcome to the forum! :)
Hello from the Crossroads of America Shaundej.
If you haven't done it yet, depending on what you are flying, it may have to be registered with the FAA.
You should take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy to take.
Welcome to the Forum. :cool:
Hi all from Sunny South Carolina
If you are a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in South Carolina, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
If you have a drone know, let us know and we might be able to hook you up with some great Links…
Happy Droning…
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Greetings from Birmingham Alabama USA, welcome to the forum!
whathesaid
