Hello from South Carolina
Welcome to the forum! :)
Hello from the Crossroads of America Cithius.
If you haven't done it yet, swing by and take the TRUST test and keep a copy with you when you fly.
You probably already have the MA2 registered, if not, here's a link for that too.
Welcome to the Forum. :cool:
Greetings from Birmingham Alabama, welcome to the forum!
New user from South Carolina. Flying a Mavic Air 2
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
As a New Drone Pilot, you've been busy and did all the legal stuff, Good On You…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Sout Carolina, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
As a Newbie, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mavic Air 2, including the User Manual.
Happy, Safe and Legal Droning…
Hello from Minnesota and welcome to the Forum....Congratulations on your Mavic Air 2....There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safe, Fly Smart...keep VLOS.
ryanhafeman
