Hello from Spain
Welcome to Mavic Pilots .
Don't be shy and ask anything if you can't find it by searching
and stay safe.. Thumbswayup
Greetings from Birmingham Alabama, welcome to the forum!
Hello from Minnesota USA and welcome to the Forum....There's a lot of good quality teaching/feedback going on in here. Just ask, and the experts are great on providing good sound advice for you to apply and use... Remember to always Fly safe, Fly Smart and keep the drone in sight.
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
Be sure you are following all of the laws and rules applicable to you in the Spain. Here is a DJI Link to Many Sites of interest to all, even those in the U.S.A.
Drone Flight Application Strategy Digest, continually updated!
Below are the links to all of the downloads offered by DJI for the Air 2S and the Mini 3.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
DJI Air 2S - Download Center - DJI
DJI Mini 3 Pro - Downloads - DJI
Happy and Safe Droning…
Welcome to the forum! :)
Reactions: Skywatcher2001
fredguillot02
