New member
Brutalwarpig
Tennessee, USA
Hello
I am fairly new to photography UAVs. I own a DJI Mini and Mini 3 as well as a FIMI X8 2022SE V2 and FIMI X8 Pro. I live and operate my drones in middle and Eastern Tennessee, North Georgia and central/Southern Kentucky. I am an industrial controls engineer and competitive handgun and long range rifle marksman as well.
Hello
Welcome from the Wild, Wild West. Midlands..... of England.
Welcome to the forum! :)
Welcome from Vero Beach, Florida.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drones that weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
FAA TRUST Online Portal for Recreational Drone Operators - Pilot Institute
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com trust.pilotinstitute.com
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live/fly in Eastern Tennessee, North Georgia and central/Southern Kentucky, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the links to all of the downloads offered by DJI for the Mini and Mini 3, including the User Manuals.
After you read the Manuals, read then again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
As far as those other drones, you are on your own…
Fly On and Fly Safe…
anton13
